Set default to "mating conditions" NX6
where can I set the "assembly constraints" default to mating condtions? Ihave it set that way in my template files but it doesnt apply to new files created from it.
I'm constantly re-setting this.
TIA
Dave
RE: Set default to "mating conditions" NX6
From the Customer Defaults
File - Utility - Customer Defaults
Select Assemblies - Positioning
You will need to restart NX for the change to take effect
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX5,6 Solid Works, Solid Edge
I'm there but I don't see where it can be changed to "mating" anywhere. None of the help definitions seem to apply either.
Dave
Ok, I found it under "extras"
THANKS!
Dave
