Postbuilder Cutcom Off
We are now introducing NX6 for our Mazak FH4800 with Fanuc controller. We want to use full-diameter cutcom on last path for some operations. However some damage part-drive-contour. For engage there is :
G1 G41 X-- Y--
For retract however there is:
G40 D00
G1 X-- Y--, can these two moves be lines into one line?
Thanks, Bert
G1 G41 X-- Y--
G40 D00
Thanks, Bert
RE: Postbuilder Cutcom Off
You may need to remove the G40 block from the Cutcom off event in Post Builder. This will output it on a seperate line.
Make sure the linear motion has the cutcom block (G41,G42,G40)
Add the G40 block to your rapid motion also
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX5,6 Solid Works, Solid Edge
Any more helpful tips, Bert?
You will get a "D" output EVERYTIME it's called.
See attached.
J
This after contact with our local Siemens technician.
Kind Regards, Bert
G0 X-- Y--
G0 Z--
G1 Z-
G1
G41 X-- Y-- D(06 for example)
G1
G40 X-- Y-- D00
