Spark Plug Wire Sets
Hi all,
I have a 1995 Winnebago motor home on a Chevy P30 chassis with a 454 TBI engine. During routine maintenance, I tried to remove a spark plug wire and found the boot was damaged (the boot split with just a little tug). So the crux of the matter is I need to replace the spark plug wires. I went to the local NAPA store and they had a replacement set but they are 7MM vice the 8MM OEM wires. I was wondering if this set would be adequate for the motorhome since the engine must work much harder than in other applications (the motor home weighs more than 14,500 lbs loaded).
I went to the local chevy dealer and they did not have OEM wires in stock. Also, the parts guy did not know whether the set he special ordered were 7 or 8MM.
I need to get this vehicle back on the road asap. Any advice would be appreciated
jiM
jiM
RE: Spark Plug Wire Sets
Rod
Rod
Blacksmith
