Reasonable Parallellism Tolerancing for stack of flat plates
Hello all,
I am working on an array reactor cell, which involves a stack of plates which are bolted together. Flatness and parallellism are highly desirable for uniform compression across the reactor membrane. I am new to geometric tolerancing, and I would like to know what a reasonable parallellism tolerance would be. The plates are 10" square by .5" thick.
Thanks in advance.
J
Thanks in advance.
J
RE: Reasonable Parallellism Tolerancing for stack of flat plates
