additional water line to distribution system
We are looking into adding 1-1/2" line to the existing water distribution system in the plant in order to bring water into the new area. Approx.10 gpm of water will be used at equipment every 10 minutes and not continuous water usage. Do I need to route piping so that water is always circulated and open a valve as needed? Or can I have dead end line and open a valve as needed? I am not piping engineer and truly need some help. Thanks.
RE: additional water line to distribution system
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
