Pipe grades
Pipe grades
Pipe grades
Can A53/A106/API 5L pipe be substituted with A333 pipe when used in crude oil refining refining?
RE: Pipe grades
I suspect "yes" if the substitution is A333 for one of the others you listed.  There would, of course, be exceptions and qualifications.
I suspect "no" - in general - if the substitution is attempted the other way.
SNORGY.
RE: Pipe grades
It would depend on the grade of API 5L pipe in use.  Some grades of 5L would be of higher strength than might be A333.
RE: Pipe grades
Thanks for the replies, I appreciate the help.
RE: Pipe grades
You also have to check if the crude oil need a HIC tested material, check the allowable stress for the internal pressure and check the weldability of the grade replaced with the existing one (Equivalent carbon).
RE: Pipe grades
Where can I find a web site which details the properties of various "Piping Schedules"
