Engineering Calculation Software
Hello All,
I would like to some advice on engineering calculations software. Is there any cheaper (or even free) alternatives to MathCAD and something that can offer better presentation and error checking facilities than excel.
OptiEng
OptiEng
RE: Engineering Calculation Software
Dik
also www.octave.org www.scilab.org for two more traditional packages that are fast and stable.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
The main points were:
Maxima is included in the Euler download, and seems to be integrated with Euler.
Wikipedia has a good comparative table:
http://
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Does anyone use a free programme that does cope with engineering units (e.g. m, Kg, etc).
My main purpose for using the software at the moment is for engineering calculations with formulas.
OptiEng
http://www.freecalc.com/list.htm
http://www.cheresources.com/software.shtml
http://www.efunda.com/home.cfm
I also really like the TI-89T handheld calculator and the PC-based software you can get for it. You basically type in an equation and pick "SOLVE" from a drop-down menu. Then, if you don't give it numbers to work with, it solves it in the form of an expression in terms of whatever alpha-numeric variable you want.
Frightening.
SNORGY.
