Which Aluminum is best?
I am designing a pressure vessel for an submarine. I does anyone have any experience or suggestions with these alloys for this application?
Aluminum 5086 H111
Aluminum 5454 H111
Aluminum 5456 H111
Aluminum 5086 H111
Aluminum 5454 H111
Aluminum 5456 H111
RE: Which Aluminum is best?
What is the overall diameter of hull and the lenght?
Does the hull is protected by coating or not?
In fact, the aluminium alloy 5086 (or 5083), alone, is the better for marine corrosion resistant. Also, the 5754 may be used.
Other aluminium alloy my be used; for example, 6082 T6 (with anodic coating).
What is the fonctional pressure ?
