selection hierarchy, visible face vs a vertex on the other side of mdl
I'm currently working  in an assy, trying to move things around, and am haveing a hard time because I click the part face that I can see, but it selects an edge or vertex of something behind the part.  I have the selection filters toggled off.  Normally the most visible face or suface is the first to be selected in my experience.  Has anyone seen this?
RE: selection hierarchy, visible face vs a vertex on the other side of mdl
Do you have any transparent parts? Under System Options>Display/Selection do you have "Enable selection through transparency" checked?
Go to Tools > Options > System Options > Display/Selection and deselect Allow selection in HLR and shaded modes
That was it CBL.  For some the obvious is not so much.
As usual you saved the day and rule.
TY
