BOMS & Configs & Derived Configs
SW09 SP3.0 Pro x64
I have a top-level assy with 15 parts and 2 sub-assys. One sub-assy has 4 Configs.
The top-level assy has 6 Configs. Each Config has 7 Derived Configs. That gives 48 total Configs in the BOM.
When I insert the SW BOM into the drawing, the QTY column header displays the dash number associated with the various Configs, but they are out of order. I have tried RMB on the header and selected various methods under Sort, but with no luck. I would like the columns with Configs to be in order from -01 to -48. Any suggestions?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: BOMS & Configs & Derived Configs
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
Anyone care to offer up a reason why I even need to do this in the first place?
