Best fit radius
Best fit radius
Best fit radius
I am looking for an equation that will solve for the best fit weighted average radius for a conic surface.  This is to correlate with our interferometer measurements.  Currently we do this by a brute force method creating sag tables of the conic surface and a spherical surface and use solver to minimize the RMS error.  I assume there is a more eloquent way to do this however.  Thank you for your help.
Rob Stupplebeen
RE: Best fit radius
I'm not sure I understand why you think there's a "better" solution.  "best fit weighted average" implies doing a statistical fit, which appears to be what you are doing.
TTFN
RE: Best fit radius
I was hoping for a closed form solution instead of the brute force sag table method.
For a given Radius, Conic, and Aperture a best fit radius should be able to be derived.  Before figuring it out myself I was hoping someone had already done it.  If not I'll figure it out and post here.  Thanks.
Rob Stupplebeen
