Belt loosening / slippage - dynamic issue?
My collegue is involved on a problem identification of a "belt loosening / slippage problem leading to failure" in a motor (11kW power) driven screw compressor after a few (20 - 30) hours of operation.
Is there anything else he needs to consider apart from the static design, contact angle, etccc? Say, whether a torsional analysis is required to see whether he is operating in some out of phase modes? Could this also be point of concern? Any other check points.
Thanks in advance
Jeyaselvan
RE: Belt loosening / slippage - dynamic issue?
I'm not sure I understand the question, but..
what type failure?
vee belt or synch belt?
what size?
what tension ?
If the "failure" was the belt burning/shredding/breaking, the installation (belt tension) is the prime suspect.
The "belt loosening" and "belt breakage" are the failure modes observed in this case. The belt is of Vee type and belt tension is set with a tensioner.
Jeyaselvan
Ahhhh...but is it set correctly with a tensioner???
And is it aligned with the pulleys, or more correctly, are the pulleys aligned wrt each other?
I suppose the belt drive could be grossly undersized for the application, or the screw compressor could be jammed, but if its an OEM design I'd get to understand the installation procedure. SHould be in the manual.
