Working with surfaces in assemblies.
Hey all. Ive got a model which I need to bring into an assembly, but it mainly comprises of surfaces, some hidden some not.
I have turned surfaces on in the assembly environment to be able to see the model, but that shows every surface in the model, some of which I want to keep hidden. I only want to display the surfaces that a currently displayed when in part environment.
How do I hide individual surfaces in assembly environment?
Thanks, James
Thanks, James
RE: Working with surfaces in assemblies.
This is off the top of my head so I don't know if it will work but it's an idea. Take a look at the simplify command in part and see if it will let you hide the surfaces that way.
Kyle
There msut be someway of doing this without dropping the parents of every feature and deleting the ones i dont need.
James
- create an intermediate part with a part copy (construction body) and choose which surfaces you need.
- create another part in the assembly and use inter-part copy to bring in the surfaces you need. After click 'show surfaces' on that part and not on the other.
- hide what you don't want and save as parasolid or step with the option 'export displayed only' and 'surfaces'.
HTH,
Fred
