Fine/Coarse Adjustment of Plate
I am looking for ways of moving a plate in an axial direction. There is a secondary plate that I want to move rotationally as well. There needs to be fine adjustment available so that a person can rotate the plate 1-2 degrees and lock in the location of the plate. The same holds true for the axial translation. I was thinking possibly a knob, worm gear, cam assembly would be the answer but wanted to get some more feedback.
Kevin
Kevin
RE: Fine/Coarse Adjustment of Plate
Can you upload a pic or drawing of your arrangement, difficult to advise on the info you have given us.
desertfox
Kevin
http://www
Harold
SW2009 SP4.0 OPW2009 SP2 Win XP Pro 2002 SP3
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
thanks,
Kevin
http://www.mcmaster.com/#catalog/115/2532/=4k6n5w.
You can also buy just the micrometer head:
http://www.mcmaster.com/#micrometer-heads/=4k6nzp.
For rotary, maybe a movable block on the rotating table that the micrometer (and spring) adjust against.
h
Here are some differential screw adjusters. You can get most any accuracy you desire. Look around.
http://search.newport.com/?sku=AJS127-02H
Here is a goniometer that maybe of interest. They are others on the market that maybe less expensive.
http://w
