Oily Water Separator Fine Filter
Gents
We are using a Hamworthy OWS HS 5 and it does separate the oil from the water, but since there is no fine filter in this unit (like the old units) therefore, although there is no oil in the water, it is not clean enough to pass the 15 ppm sensor, due to rust or carbon particles.
My question is what type of filter (brand and model) can you recommend?
The flow is aprox 83 lit/min.
Best regards
