Modeling a wire mesh
I'm attempting to model and analyze a tennis racquet but I am stuck on the string mesh. I was thinking of making a long complicated spline, and then sweeping a small diameter circle along that.
Is there any other way around that?
Any help is appreciated. Thanks in advance.
RE: Modeling a wire mesh
Rob Stupplebeen
If you are trying to identify the center of percussion, I don't believe that requires strings... just of function of frame geometry and mass... It has been a while since I took those classes.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
