Hydrostatic Test in Atmospheric Tanks
Hi Folks,
If I have to wave a Hydrostatic test in an Atmospheric Tank, 200 ft diameter and 60 ft height because of economical and time reasons:
How can I compensate this test with NDE?
Is Hydrostatic test defined as a leak test or for testing the mechanical integrity of the tank?.
How is the risk associated if I do not perform such test, advantages and disadvantages?
Best regards and really appreciate your quite important opinion.
RE: Hydrostatic Test in Atmospheric Tanks
Learn the rules,so you know how to break them properly.
Dalai Lama
_____________________________________
You could consider RT or UT of the welds but that would be very expensive.
Your QA people should be consulted.
