Solidworks BOM and Rows
If you have a large BOM and you have to change the row height to accomadate the description. You have probably found that the row numbers do not keep up with row size changes.
This is a known bug, however SW has had few hits on this. If you find this to be as annoying as I do please ask your VAR to add you to the list. The more hits that are applied to a bug the sooner something like this can be fixed.
455130 - Row numbers are not aligned with rows in the Bill of Materials (BOM)
Scott Baugh, CSWP ![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376: Eng-Tips.com Forum PoliciesQuote:
"If it's not broke, Don't fix it!"
RE: Solidworks BOM and Rows
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
