Can i generate Gerber files from Solidworks?
I've designed a PCB trace in solidworks that i'd like to export to gerber files to build a PCB. Is that possible?
Any suggestions?
Any suggestions?
RE: Can i generate Gerber files from Solidworks?
You need a proper PCB design program to output gerbers. There are many free/cheap ones out there like Eagle or Diptrace.
http://www.artwork.com/gerber/index.htm
There are a host of reasons for using the proper tool to do something.
TTFN
Keith Cress
So what did you use for the DXF to Gerber conversion? I've only found LinkCAD so far. It is a very nice tool but a bit pricy.
John D
