Electric Motor what does ANF stand for
We are attempting to interpret the nameplate data on a 700 HP motor and
wanted to see if you could help. An aluminum smelter bought a used
Allis Chalmers 4160 volt, 700 HP Type ANF motor per the nameplate data We are having trouble determining what type ANF
is. We will use the type to determine the locked rotor amps so that we
can calculate the flicker. The motor will be used in a shredder/hammer
mill installation.
The following is the information on the motor
Allis Chalmers Serial 45460
HP 700
RPM 697
Service Factor 1.0
Volts 4160
Amps 100
Load Resistance
Type Anf
My question what does the ANF stand for
Thanks in advance for any help
mill installation.
HP 700
RPM 697
Service Factor 1.0
Volts 4160
Amps 100
Load Resistance
Type Anf
RE: Electric Motor what does ANF stand for
I am not specialized in such sized motors, I just guess!
