problem with hole wizard
when i click on the hole wizard in Features ,i see this errore:
Error:  Could not find the Standards database 'D:\Program
Files\SolidWorks\data\databases\swbrowser.mdb'
what should i do??
RE: problem with hole wizard
sorry i forgot to say "my solidworks version is 2009"
1. Can you find the specfied file in the specified location?
2. If not, can you find the specified file on your PC and copy it to the specified location?
-handleman, CSWP (The new, easy test)
i can't find it in this location or anywhere in my computer.
thanks
when i was typing 'anywhere', after that i felt i'm in doubt. So i searched again and i found it in this path:
D:\Program Files\SolidWorks\Toolbox\data utilities\lang\English
so i copied that file in the location and it works!
thanks for your attention
problem is solved
You probably should have changed the path under your Tools\Options\System Options\Hole wizard\toolbox to that location rather than moving the file.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
