Explode Crosshatching in NX 6
I have a product label that is composed of text features (in modeling) that have been filled with crosshatching. Now in my ISO drafting view, the text on the label shows through the components that are in the foreground. In a view dependent edit, when I want to delete the crosshatch, the entire block of text is all you can select, so it will delete more than what I want to delete from the view. Is there a way to explode the crosshatching so that I can delete only the portions that should be hidden by the components in the foreground?
RE: Explode Crosshatching in NX 6
If not, I would put the crosshatching on a different layer (if possible) and not show that layer in the drafting view, then add the partial crosshatching manually. The reason being is that if you're able to explode crosshatching, it will probably end up as individual lines, which you'll have to trim each line to a boundary for the partial hatching you're wanting to see.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
