ver small vessel level sensor
I'm looking for a non contact level sensor for use in a container that has a range of 0.5-6 inches from the sensor. The material is a clear liquid and has chemical compatibility issues, but even without considering that I haven't found anything acceptable. I have looked at a couple ultrasonics but they haven't met my dead band criteria.
Can anyone help me out with a manufacturer to look at?
Thanks.
RE: ver small vessel level sensor
I'm looking for something with an analog output. But thanks for the link, being in Canada I completely forget about RS sometimes.
I know you said non contact but have you considered a teflon covered capacitance type. You could use a fat probe to maximize on capacitance change.
I think radar might work also, I believe the dead zone is much shorter than ultrasonic.
Roy
dp cells always work.  Radiation-Based Level Gages are available too
How about weigh cells?
______________________________________________________________________________
This is normally the space where people post something insightful.
Being in Canada have you looked at the Siemens / Milltronics Radar?
