Export to spreadsheet in NX5
i am having trouble to export my assembly to a spreadsheet.
i do have the preferences set to excel and also in excel have the "add-in's" set to ug. when exporting i get this error message "failed to set excel running". i have sent this to GTAC but have yet to get an answer. has any one encounter this and solved this issue?
Scott Copeland
Mould Designer
G-Mag International Inc
www.g-mag.ca
RE: Export to spreadsheet in NX5
When asking questions about software interaction, it helps to know all the information.
Does Excel work as a Family Table editor for you?
Can you create a drafting table with Excel in NX5?
Ben Loosli
same error message appears " failed to set excel running"
Scott Copeland
Mould Designer
www.g-mag.ca
Now that you have 2003 installed, try to do a repair install on NX5.
Ben Loosli
