Need Help with Plotting multiple lines
I am plotting 6 curves on one plot.  5 of those will be using the left axis and the 1 using the right axis.  Each line will have a different color.  The code that I have is giving me colors that do not match up with the lines.
M = csvread(filenameAndDir,1,0);
t=M(:,1)/60;
T=M(:,2);
T1=M(:,3);
T2=M(:,4);
T3=M(:,5);
T4=M(:,6);
T5=M(:,7);
A=M(:,8);
[h]=subplot(2,1,[1,2]);
annotation('textbox',[.5 .9 .1 .1],'edgecolor','none','string',filename);
set(gcf,'DefaultAxesColorOrder',[0 1 0;0 0 1;1 0 0;1 1 0;0 0 0;0 1 1;1 0 1]);
[AX,H1,H2]=plotyy(t,T,t,A);
hold on;
plot(t,T1,t,T2,t,T3,t,T4,t,T5);
hold off;
grid on;
set(AX(1),'YLim',[20 120],'YTick', [20 40 60 80 100 120]);
set(AX(2),'YLim',[0 100], 'YTick', [0 10 20 30 40 50 60 70 80 90 100]);
ylabel(AX(1),'Temperature (C)')
ylabel(AX(2),'Heat (kJ)')
xlabel('Time (mins)')
title('Heat Production')
legend('Temp1','Temp2','Temp3','Temp4','Avg','Water','Heat',1);
The way that I want it is:
T-Green
T1-Blue
T2-Red
T3-Yellow
T4-Black
T5-Cyan
Q-Magenta(what is the code for orange?)
Any help would be very much appreciated.  Thanks in advance.
RE: Need Help with Plotting multiple lines
Just type the color after your pair of values
plot(t,T1,'gr',t,T2,'bl',t,T3,'r',t,T4,'ye',t,T5,'cy');
and so on. but look in the help for plot there should be everthing explained.
Phaneas
