Replace part in Vault
I serached the help, I couldnt find.
I have a assembly & all its part & drawings checked into PDM works/Vault (Not Enterprise PDM). How do I replace a part (All instances) with another new part?
RE: Replace part in Vault
Unfortunate.
There should have been a way to handle parts in the vault directly. This is one the basic PDM action.
if possible, give the new part same name as the old one & check it in.
If needed check out the old one first & rename it before renaming the new one. that way you will have the old part as well.
Cheers
Gurjjeet's suggestion will work, with one caveat: the models will be intact if, and only if, the replacing part is similar in design to the replaced part. Otherwise you'll have broken mates, etc. to deal with. Just something to think about. It's a working method if you're very, very, very careful.
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
ITs not worth it to me then... it would be easier to check out replae the part make sure its correct, check back in and roll the revision back.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
