Extract PEP
Extract PEP
Hello to everybody.
I've question and I hope somebody can help me. I'm sure that somebody helps me.
I've learned to use script to extract data in an automatic way. In this case I need to extract the PE Max.Principal but I can't understend how Abaqus saves this information. If I look at result tree I arrive till the output PE that is a tensor in which I can find only its six components.
Any advice?
Thanks in advance,
Jam3s
Any advice?
Thanks in advance,
Jam3s
RE: Extract PEP
temp2 = odb.steps['Step-1'].frames[-1].fieldOutputs['S']
temp2 = temp2.getSubset(elementType='COH3D6')
temp2 = temp2.getSubset(position=INTEGRATION_POINT)
field = temp2.getScalarField(componentLabel='S33')
RE: Extract PEP
can you explain better these commands?
RE: Extract PEP
lookup Scripting reference manual in abq help and search for get subset, get scalar field
