Modifying Oil Viscosity to Suit Your Needs
I read somewhere that mixing oils in 2 viscosity ranges to obtain an average viscosity was OK to do as long as they were the same brand (due to differences in additive packages.) Now, 10w40 synthetic oil isn't recommended these days because it has much more viscosity index improver than say 5w30 (none) or 20w50, or so I hear. A 15w50 oil is too thick for me at this time, so if I wanted to increase the viscosity range of the 5w30 oil I currently use, I should be able to make a 50/50 mix of 5w30 plus 15w50 for an approximate 10w40 combination, right? I'd like to hear your thoughts about this.
RE: Modifying Oil Viscosity to Suit Your Needs
If mixing oils were that big of a problem today, I'm sure the world would be hearing round after round of oil catastrophe stories. which really don't seem to be happening on well maintained cars.
That is not to say that you should be mixing in 20W-50 oil in your new engine during the winter in Fargo, North Dakota, but I think adding oil is like shooting a shotgun. For most non-critical everyday applications, close is good enough as long as its the proper API service class or better and changed at the service interval written in your owners manual. Severe weather and critical use conditions excepted.
Chumley
Blacksmith
or even better stuff a 460 in there and keep your old motor to drop in for emmisions tests.
In practice it is not really a problem unless it is causing plug fouling or excessive oil consumption. I personally don't get too excited unless consumption exceeds one quart between my usual oil changes and, even that is subject to question (as in a truck with a VERY large capacity sump).
Quite often in todays business world you find that additives and viscosity index 'improvers' are manufactured by chemical companies supplying the ENTIRE lubricant industry! Mixing various brands and viscosities just is not normally a problem. Just don't go to extremes as I once did and fill the sump with STP !!! (I was 'away' from home in a bugeye Sprite with a standard crank and 0.010 undersize bearings. I started the engine and drained oil as I added STP. Don't laugh, it got me home 900 miles away and NO damage!!!)
Rod
If you look at more recent US oil specs you will notice that nowadays in the more severe specs a socalled "NOACK"-volatility test is used - a test to establish the volatility originally developed in Europe and used there for decades. In practice this means that modern synthetic oils do meet these requirements where old fashioned lower spec oils might not.
A recent lab testing of leading 10W-40 synthetic oils showed a range of volatility on the NOACK test from 4.73% to almost 10% among the top 4 brands tested.
Another NOACK test of top selling 15W-40 synthetic oils showed a volatility range of 6% to almost 14%.
Testing the top six synthetic 10W-30 oils showed volatility ranging from 6.7% to almost 18%!
As far as Viscosity Index (VI) improvers go, there is wide variety in the quality of VI improvers, and their ability to resist sludge formation over time. Additionally, there is a wide variety in the quantity of VI improvers used by various manufacturers.
Recommendation: Use a top-line synthetic oil with the lowest volatility and highest quality VI improvers (if any)from a manufacturer that has the most experience in synthetic oil technology.
Will
NOVA Engineering & Consulting
novaeng@tampabay.rr.com
