Detecting copper plating in steel cylinder
I urgently require a low ohms meter that will detect anodic copper plating as it is laid down within a 6 ft x 2ft diam steel cylinder. I intend to check for significant reduction resistence through the lenth of the cylinder.
Low ohms meters are extreemley expensive.
Perhaps someone could tell me what would be required to make a simple fixed low M ohms circuit tester for steel
Or am I being unrealistic..
Perhaps you know of a low cost ohms meter for steel.
RE: Detecting copper plating in steel cylinder
Vita sine litteris mors est.
