calculate beam spring rate
How is spring rate of a simple end supported beam calculated. Is it simply deflecting force in lbs/deflection in inches.
RE: calculate beam spring rate
Work out the deflection at the point of load application then divide by the deflection.
desertfox
I assume you mean divide the load force by the worked out deflection
Yes in a nutshell however you need the deflection directly under the load your applying
desertfox
You will have to work out the SS beam deflection as desertfox indicated.
Fe
