motor wireing
motor wireing
I have a nice emerson 3/4 horse two speed motor. Got it to run, but weak.
wires: blu, red, blk, brn, and wht.
mdl# is emerson s67pxerr-5231
would welcome help.
Retred
would welcome help.
Retred
RE: motor wireing
RE: motor wireing
RE: motor wireing
Motor has square housing, open frame. I ran into the same problem with the mdl #.
Maybe I need to do some more work with the ohmmeter, and isolate the windings. Maybe experiment with a capacitor.
the listed speeds on the plate are 1725 and 1140
thanks,
Retred
RE: motor wireing
1725/1140 may be two separate windings. Easy two speed transitions give 2:1 speed ratios. Most other ratios use two windings.
Bill
"Why not the best?"
Jimmy Carter
