Excel based moody chart.
  I need to calculate friction factor for different reynolds numbers or relative roughness, does anyone have a moody chart that is in a spreadsheet that I may use as a look-up table?
Better yet, the correlations for each trend?
RE: Excel based moody chart.
Try looking up "Colebrook Equation".
The information you get will explain things better than I can.
-- MechEng2005
Thank you for this valuable help!
Churchill eliminates the iteration of Colebrook and works for laminar through turbulent flow.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
