assembly rebuild icon wont go away even after hard requild!
I have an assembly Ive worked on for the past month, and today It has a rebuild symbol on the top of the design tree, where the name of the assembly icon is. I've searched thru the tree, and cant find it anywhere else, I've done ctrl q for the hard rebuild, and it doesnt change. I've been thru the mates, and there's no problems there. Has anyone seen this? And if so is there a solution?
RE: assembly rebuild icon wont go away even after hard requild!
Aaron
SolidWorks (x64)/PDMWorks 09 3.0
CADKey 99 R1.0 (Yes, still using it!)
Something you have done in the last day or so has caused this if it was not there before.
It is not just mates, any feature that is made in-context can cause this. You have some feature/sketch A with a dependency on another feature/sketch B which has a dependency on feature/sketch A. A circular reference.
They can be a bugger to fix if you do not attend to them as soon as they show up when you still remember what you just did to cause the circular reference.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2010 SP0, Windows 7
http://www.solidmuse.com
http://www.phxswug.com
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
"S-037560" in the Solidworks Customer Portal Knowledge Base you will get results that appear to be the issue, and the fixes they mention do seem to work.
Aaron
Aaron
