barrel threads for hydraulic cylinders
i would like to know if there is a standard thread series for internal/external metric hydraulic cylinder barrels with corresponding bore size for threaded end caps -
i have a copy of internal/external barrel threads in inch sizes but cannot find anything on metric threads - any help would be apprecaited - thank you
RE: barrel threads for hydraulic cylinders
http://www.crconline.com/
I've haven't bought any components, only some rod but just assumed they knew something about metric components as they state, call if you need metric.
I also assumed that they would know about metric from all the heavy equipment working around here is from Japan.
This will have to go in my loser's column.
For example, 1.000 - 8 UNC-2G may translate nicely to a M25 X 1.5 6H equivalent. Then crank out the mathematics to ensure fracture mechanics are within acceptable limits given your constraints under loading.
Seems like a reasonable academic approach?
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
We use 12 threads per inch on threads from 2" to 5" for most fluid power applications. If the cylinder wall thickness is thin use a finer thread, if wall is thicker use a coarser thread. For head glands that screw in use acme threads, the pitch will be determined by the wall thickness.
Ed Danzer
www.danzcoinc.com
www.dehyds.com
http:/
Maybe try a European manufacturer - Atos is one:
http://www.atos.com
They are a leader in hydraulics.
or here: http://ww
or here: htt
ISO 6020-2
DIN 24554
