Viewreps not really locked
I'm sure that I'm being a bit dim and missing something obvious but I have an occasional problem when I insert new parts into an assembly and they appear in locked viewreps.
I thought the whole point of locking the viewrep was to prevent this.
It makes it worse because some of my assemblies have the problem but some don't and I have no idea what is different between the assemblies. Is there a setting which I have inadvertently switched off/on?
Any help would be gratefully received.
RE: Viewreps not really locked
So they show if you have the locked view rep active only to aid in placement but really are invisible when the view rep is reactivated.
It's not too bad because I can unlock the view reps, make the new parts invisible then lock it again but it's slightly irritating because it's not waorking how it's supposed to.
