give a cutout a different color?
I have made a 2mm cut out in a part and would like to make this "ingravement" in a different color than the part. How do I do this?
RE: give a cutout a different color?
You can use the part painter. You can select a different color and apply it to a face, a feature, all features of a certain type, a body or everything. It is under the format menu if you are on a release prior to ST. It's a pretty handy tool.
Kyle
It works when I am in the part mode but when I switch back to assemble mode and render the object, the whole part is of the same color. Any solution for this?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
