Machined weldment
Machined weldment
I am looking for some help on drafting a weldment.
The part, as we make it, starts out as just a weldment with a BOM for each part and welding callouts. I want to then create a second drawing showing the machining. What I have been doing is creating a draft document with two sheets. Sheet one has the assembly and sheet two shows the weldment for machining purposes.
The only problem is that the welds don't show up on the assembly drawing. I know that I can hide the welds in the draft environment, but what I really want to do is hide the machining.
Has anyone found a beter way to do this?
