Delete Drawing Reference
Hello all,
I have a drawing that is referencing 2 different assemblies.  I need to delete one of them and using the "file/open" shows both but does not allow me to delete anything.  I did the search in the forum but none of the answers seem to address deleting a reference.
RE: Delete Drawing Reference
The only way to completely get rid of a reference is to open the drawing and delete the views referencing the assembly in question.  Is there a good reason why you don't want to open the drawing?  If the assembly is giving you errors, you can change the reference to a different part or assembly.
I wish there was an easy way to delete references.
Per takedownca, you need to check each sketch of each model to break the reference.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Thanks guys, comments appreciated.  I will move forward as recommended.
