opening multi part/sheet drawing opens all referenced models?
I've recently started using sw09, and just noticed that when I open a drawing file, with multiple sheets, (each sheet has a detail of different parts), while its opening the drawing, each of the part files are opening as well.  This didnt used to happen to me when I was running sw08.  Is there a setting I must change so this doesnt happen, or do I just have to deal with this?
RE: opening multi part/sheet drawing opens all referenced models?
Tools --> Options --> External References --> Load referenced documents set to none. Check that.
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
yOU GOT IT.
tHANKS
Glad to help.
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
