Transfer .dwg to Solid Edge Model
A customer gave me a logo drawn in autocad that he wants engraved onto his part. I was wondering if it would be possible to add the drawing to a model created in SE, and if so could you give descriptive steps.
Thanks in advance.
Thanks in advance.
RE: Transfer .dwg to Solid Edge Model
If you open the dxf/dwg file as a solid edge draft then that will convert it into SE.
You can then use the now Solid Edge geometry as you see fit.
One way is to create a sketch in the model and then paste the logo from the SE draft into it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
