high helix ball screw with backdrive powered by a torsion spring?
Hello
I would like to know if this is fundamentally possable.I am a industrail designer so could do with some engineering help please.
I have a good product idea that requires a ball screw device powered by a torsion spring to act in a simular way to a low powered gas strut.
the screw is required to have a linner range of 150mm (the spring will provide power for 4-5 revolutions.
over this range the screw will be required to support a load of 8kg (up and on the back drive) the load will be lifted and pushed down by hand the screw will only be required to support the load in the same place when you let go. the lead/ballscrew can be 260mm long and up to 40mm dia.
is this possable?
is this possable?
RE: high helix ball screw with backdrive powered by a torsion spring?
Can you give us more details about your screw, I have never seen a conventional torsion spring do more than about 120 degrees during operation and its torque capablity decreases as it unwinds, however a large spring like a constant force spring or spiral spring might be able to do it.
A sketch of your device would help.
desertfox
-handleman, CSWP (The new, easy test)
thanks again
Yes I have a torsion spring on my garage doors but to my knowledge it doesn't revolve through complete turns.
At this stage, I must say I don't know about the constant force spring whether one could make one for your application or not, I'll need to look into my books,what I will say is that it might not be cheap to make such a spring like anything else it depends on quantity.
I'll look further into when you post your drawing.
desertfox
Take a closer look at your garage door. If it's the torsion spring style then it turns through many revolutions.
andrew0wills,
Torsion springs are not constant torque. The more you twist them the more they resist. That means that your load is unlikely to stay where you put it. You might counterbalance this by varying the pitch on your screw, but that would make your sprew a pretty expensive part. If you want to continue down this path, you could look at power springs, but they won't have the same packaging as a torsion spring.
the main spring of a mechanical watch.
Try Redditch or Birmingham for springs.
To compensate for "unwinding torsion fall" tapered rollers and fusee chain connected the spring output to the movement
on early watches.
They where called "turnip watches"in Coventry where these
time pieces where made.
