Concrete to Masonry Retaining Wall Joint
Does anyone have any advice on a concrete retaining wall butting up and in line with a masonry retaining wall detail?
im looking to seal the joint.
RE: Concrete to Masonry Retaining Wall Joint
example if it was a computer sealed room, the joint deal would be a specialist item, with a water stop, heavy dowels across the joint, 40mm joint detail, backing plate with water expanding stops and some tanking to top it off, because these things have a 05 humidity requirement.
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that them like it
