Fresh Water Corrosion
I have a narrow boat on the canal system in the UK it is only four years old and some of the 10mm bottom plates are badly corroded,and one of the plates welded to the others is fine,as it is flat bottomed they are all at the same depth.I have had metallergy tests done, the only differance is in the manganese content, on the bad plate it is 0.51%,and on the good plate 1.08% would this account for the corrosion.
RE: Fresh Water Corrosion
Mike Halloran
Pembroke Pines, FL, USA
I know that can do it quick, just something to check.
Engineering has always been my love, but it ended up being my second career...
Bill
"Why not the best?"
Jimmy Carter
