Base Line Dims
Base Line Dims
Base Line Dims
Is there any way to explode baseline dimensions in NX4 so they move independantly, or is it a case of delete and add single ones. I can't find anything obvious.
Many thanks in advance
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
RE: Base Line Dims
I try this delete:
from outside the baseline dimensioning mark a single dimension an hit delete.
for add:
activate the baseline dimension set an add the edge you want to dim.
RE: Base Line Dims
If you delete a single dimension, all the others still remain as base line dimensions and the offset is still associative, or have i missed something?
Best regards
www.jcb.com
RE: Base Line Dims
hey simon,
thats the mess with controlled origns:
when you use during dim. placement - on the placement toolbar the Icon with A and the chains turn it off - thats all
RE: Base Line Dims
OK with you now, I see what you mean.
Best regards
www.jcb.com
