Volume reduction coefficient for aggregate base course
I wanted to find out about the coefficient or the volume reduction percentage to used for for aggregate base course.
MDD - 2.37, with moisture content of 6%.
98% compaction of MDD is require
RE: Volume reduction coefficient for aggregate base course
sounds like a homework assignment.
I think students would understand that numbers must be referenced with their appropriate units though. . .
f-d
¡papá gordo ain't no madre flaca!
Use weight-volume relationships for before and after conditions.  That will give you the appropriate factor.  If this is a homework problem, don't post again.
Hint provided, you solve it.
