Battery charger - help please
Hi
I have undertaken a project for which I have to build a battery charger. Here are the specifications for the charger, It has to synchronously charger up to 4 batteries synchronously.
I am at a point where I am looking for the design alternatives for the battery charging part. The first alternative I had was to use charge using the microcontrolller, secondly I am thinking to use IC's ( that I have found from texas instruments) which basically exist for charging multi chemistry batteries.
I need more alternatives because I feel There could be other better ways of going about this.
thanks you for your help
RE: Battery charger - help please
Mike Halloran
Pembroke Pines, FL, USA
