End of Slot as Datums?
7
I have a part that has two protuding slot features on it.  The part is made of Rubber.  The two protruded slots are what locates this part in the assembly.  I want to call out a profile of these slots but I also want to call the end radius as y and z datum  Please See PDF.  What is the proper way of doing this?  Will the R.16 be basic or have a tolerance?  Should I say three surfaces on the profile instead of all around? Suggestions. Wow two questions from me in same day.  Sorry.
RE: End of Slot as Datums?
Hmm, what you have is 'orrible at first glance but I'm trying to properly understand your intent before I say too much.
Certainly if you want to use the surface profile all around you either need to make the entire slot controlled by it and make the rads basic or, explicitly identify which surfaces it applies to as per Fig 6-13 from ASME Y14.5M-1994.
Can you explian really what you mean by using the end radii as datums?  I think your secondary and tertiary datum between them want to fix it's translation (top to bottom and side to side as shown in the print) and its orientation (rotation).
Given the way one of the slots is angled to the other and to the overal part, I wonder if you'd be better using the horizontal slot feature to get both your secondary & tertiary datum and then relate the other 'slot' to it.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I agree it is not the best way of doing things.  By using the end of the radii on the two slots the CMM can easily pick up one radius as the Y datum and the other as the Z datum.  I am up for suggestions here.  I just need to make sure this part fits in to a channel.  I could change the slots to protruded pins,But the ENg likes the looks of the slots and wants to keep them.  I understand I need to make the R.16 basic.  But can you attach a Y datum to a basic dimension.  I guess this is where I am getting confused.  Looking at 6-13 now.
Using a cylindrical feature as a secondary datum feature typically fixes translation but leaves rotation unconstrained, you get two theoretical plantes intersecting at right angles to the datum axis but not oriented to the overal part.  Take a look at section 4.4.2 7 figures 4-5, 4-7 & 4-9 in ASME Y14.5M-1194 and associated text.
To get the rotational orientation you add another datum (4.4.3).  My Concernt is how your Z is interpreted in this context.
Looks like the GD&T equivalent of moving across state lines in order to marry a cousin.
Thanks for that comment so what is your suggestions?  These features are the only features that locate this part. I do not need to use surface profile. I would like to get the best Datum structure as possible for this part.  How you would set the y and z datum structure up?
Kenat I looked at the veiw you mentioned.  All the datums are in the same plane.
I forgot to type the first part...
Some things are "legal" but very questionable.
I would use the width of the "Y" slot as the horizontal datum and the length or an edge as a vertical datum.
-OR- use the straight edges as datums and constrain the slots as a pattern, perhaps with a composite tolerance.
The slot ends are not going to be easy to pick up with any accuracy, even with a CMM.
Given the generous tolerance you have on the profile, I would wager there are many better ways to dimension and inspect this part and get a good result, even if the scheme is not 100% aligned with your design intent.
The last sentance of my first post was meant to be something like Ticks 1st suggestion.  Use the horizontal slot, either width or length, I'd suggest length as it's a longer feature to give you orientation, as your secondary datum.  I'd then maybe use the width of the slot as my tertiary datum.
However, this is assuming the fit to the next part is very much constrained by the location of the slot.
Given that you say it's rubber, and the fairly loose tols, I wonder if this is a case as Tick says where you don't have to stick really close to theoretical function in order to get a workable solution.
The tolerancing of the slots is incomplete.  Also, Y and Z are to the center of the slot radii to which they attach.  I'm guessing you actually want there farthest points to be the constraint?  For this, you'll need verbage on the drawing, because (correct me if I'm too lazy to look this up) I do not believe there exists a standard method to create a datum to a "farthest point from such and such" on a curve.
Also, I ASME has a method that better controls slots, though it is a bit more work to set up, and profile allows you to short cut your datum scheme (if you want the centers of those radii to be your datums).
For style, attached the Z and the Y to the bent portion of the radius leader.  This is a bit cleaner than globbing it directly onto a radius.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
Tick -- moving across state lines;  flogging;  you're a riot!
John-Paul Belanger
http://www.gdtseminars.com
Great feedback all thanks
I will review these suggestions and update the drawing.  Maybe GD&T with datums do not need to be used.  I am going to review this with the eng and post the results when we get something that can agree upon.  Thanks again.
Oh ok This is an unusally different part.  That is why I come here to the people who know the standards inside and out.  I think we are going to call out how kenat talked about using the width and the length of the horizontal slot as the y z datum.  I think I am going to set the datums up this way.  Thanks again.
correct me if I'm wrong...
If both slots are controlled by the same control frame (w/ two arrows), then you can control their relative position to one another with just the "X" datum (maybe add a second datum for orientation).  Then a second frame to control the position of the pattern on the plate.
Can composite tolerancing be applied to profile?
sdeters..
i would caution you that the horizontal slot is actually a TAPERED slot as shown. even changing the r .16 to basic leaves you with a tapered slot.
that said, the y14.5-2009 standard will allows the use of a 'linear extrusion', i.e. the horizontal slot, as both secondary and tertiary datums. this allows you to locate the angled slot with basic dims, and gives you rotational control of the entire part (after locating the slot to one of the edges of the part, of course.)
teddykaye
TK369 I will look into the 2009 standard about this.  We have to stay with the 1994 standard but it does not hurt to look at the new standard.
Peterstock.
Thanks for that feedback.  I was thinking that same thing and I am moving torwards that way of setting the datums up.
I have taken that type of info from Kenat you and thetick and assumed that it meant what you have posted in your file.  Thanks for all the help
sdeters,
Before recommending a datum structure, I would need to know exactly how the part's degrees of freedom are constrained when it interfaces with the mating part.  Specifically,
1. What is the geometry of the features that the slots mate with?  From your descriptions, it sounds like the mating part has two pins, with basic spacings of 5.444 in the X direction and .398 in the Y direction.  Is this correct?
2. What is the size tolerance of the mating features?  Or are they adjustable in size to achieve a snug fit with the slots?
Once these questions are answered, then the datum features (or possibly datum targets) can be specified appropriately.  Tolerances can then be applied to the various slot surfaces and to the features that need to clear the channel.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
Kenat, your right I should have included a "4X FULL R" callout.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
AXYM
This part covers a channel.  Think of a long c shaped channel.  This part just covers this channel using the two slot shapes to keep the part aligned in the channel. So the width of channel in the mating part is sand cast and has sand cast tolerances.  The tolerance on the channel is +/-.030.  This part is acting as a cover and we need to have the slots act as the guide during assembly.
sdeters,
Okay, that helps a bit.  But more details are needed on how the two slots align and guide the part.  Exactly what are the slots in contact with?  Are there some sort of pins or bosses on the channel?
Evan Janeshewski
www.axymetrix.ca
Please see pdf file.  The cover is located by the side walls of the casting.  These walls are as cast. The slots fit inside the channel. I hope this answers your question.  It is a loose fit nothing tight at all we just need to cover this channel up and we are using the slot tabs on the cover to keep it in place during assembly.
sdeters,
Okay, now I see it.  The latest diagram cleared things up a lot.  I had been picturing something very different.  I got hung up on the term "slot", which I normally associate with some sort of cutout and not a solid feature.
I'll think about it during lunch and post something later.
Evan Janeshewski
www.axymetrix.ca
Sorry sometimes I am not to clear.
From what the OP has provided, the length of the protruding slot (boss?) is not controlling any DOF.  I agree with the width of the horizontal being shown as datum feature Z, however the Y  on the length of the feature won't do anything for you in this situation.  The horizontal location and rotational motion will be controlled by the width of the second elongated boss; so, the datum Y callout should be inline with the arrow of the other .316 width dimension.
Jim Sykes, P.Eng, GDTP-S
Profile Services  www.profileservices.ca
TecEase, Inc.  www.tec-ease.com
Now, with all of the extra information (and seeing the mating part), I like the way MechNorth is heading using the widths of the two slots dimensioned pretty much like PeterStock's second version. While I understand people like to start from the edges. I prefer to give some insight to the function. if the edges are not important I want it to look that way. If manufacturing wants to use an edge it's OK but it is'nt important to the function as I understand here.
Looks like the part locates on the face and the two widths. Why there is that angle to the maiting psrt I don't know but if it's the way it is so be it. I like where you are going MechNorth.
Sorry, not slots bosses.
The boss widths will locate the part and stop rotation the end radii, that we started with, just have to stay out of the way.(meaning controled not to touch, in istallation).
Here's a crude depiction of the functional situation (see attached).  The cover (blue) is to placed on the channel (red).
So the first functional requirement is that the two bosses must both fit into the channel without interference.
The second functional requirement is that the outer edges of the cover must maintain some relationship to the channel.  This needs to be clarified - perhaps sdeters can give some guidance on the requirements for the cover's orientation and location relative to the channel.
In any case, we know that the bosses are the datum features.  That is, contact on the boss surfaces constrains the cover's remaining degrees of freedom (one rotation and two translations).  Exactly which of the boss surfaces participate in the DOF constraint, and how, will determine how the datum features need to be defined and referenced.
Evan Janeshewski
www.axymetrix.ca
Evan!  That looks like the same mfg workmanship as my last shop!  ;~}
The Outer edges in the original drawing posted was a just a rectangle I put on the drawing.  Those edges did not serve no purpose what so ever.  They are just tossed on there.  I have attached a drawing please take a look.  The outer edges (hidden) on the part need to cover the channel and not fall in the channel when the part is shifted around during assembly.  This part seals oil in the channel.  I will have another part that bolts to the channel that will squeeze the part in question for the seal.
sdeters,
Fit and function requirements for the assembly!  Now we're getting somewhere.
You mentioned that the tolerance on the channel is +/- .030.  Is this tolerance on the width of the channel, or the profile of each side of the channel?  Also, what are the nominal inner width and outer width of the channel, and the nominal outer width of the cover?
Jim,
The profile accuracy of my sketch is what a mouse and two cups of coffee will allow.  The thing is, the parts might literally look like that and still function.  The as-cast channel surface probably does.
Evan Janeshewski
www.axymetrix.ca
I thought we were going to pick up both bosses simultaneously (sp?)?
That's what I understood as well, fsincox.  Peter, your datuming scheme doesn't represent that functionality.  Thoughts?
Evan ... just like my old shop!!!  Actually, probably worse when someone missed a nicotine break and was loaded up on caffeine!
The tolerance is on each surface of the channel and in the drawing it is dimensioned by a surface profile .050 back to XYZ. The width of the Channel inside surface to surface is .380.  The width of the channel outside is .730.  On the cover to start with I was going to make it line to line with the outer width of the channel with the slot bosses centered in the channel.  Then let the part slide on the X datum until the cover slot bosses hits channel.
Thanks for all the feedback again the info that has been provided has been great and very usefull.
Yes, fsincox and Jim are right, the datum features in Peter's drawing don't match the actual DOF constraint and need to be changed.
The attached sketch is a depiction of what would happen on my actual part if this datum scheme was used.  The black blocks are the two vise-like datum feature simulators, which contract onto datum features Y and Z.  The datums are the centerplane of simulator Z and the center point of simulator Y.  The red geometry represents profile boundaries for the bosses and the outer edge.  These boundaries have the proper basic relationship to the datums.  Note how the slight skew of the right-hand boss skews the simulators, and thus the datums, and thus the tolerance zones, along with it.  Because the boss is so short compared to the length of the part, the projection effect magnifies the apparent error.  This wouldn't happen in the real assembly, because the right-hand boss doesn't constrain the rotational DOF on its own.  If the parts were inspected with this datum scheme, a lot of functional parts would probably fail.
Both bosses play an equal role in constraining the degrees of freedom, so the datum referencing needs to reflect that.  We need some way of referencing the surfaces of both bosses as a combined datum feature, without giving one boss precedence over the other.
Unfortunately, Y14.5M-1994 does not provide very good tools to do this on "irregular" features like obrounds.  We may have to cobble something together that gets close to the right result.
Evan Janeshewski
www.axymetrix.ca
No, I wouldn't do that.
I think MechNorth and others are proposing:
http://files.engineering.com/download.aspx?folder=4fbd530a-ca70-4d6f-bcc7-a053361f623d&file=ANGLED-DATUM.tif
Based on my extrapolation of figure 4-4 & section4.4.1.1 of ASME Y14.5M-1994.
This most accurately reflects function as I understand it.  However, if the cover truely is rubber and hence compliant, part of me wonders if it's worth the effort.  Though that's probably 'cause I'm a bit out of practice.
Ok sorry it was just a thought that came to my mind as I was going through the posts. Thanks
sdeters,
I agree with KENAT that your latest version is not a good direction to go in.  The way I like to think of it is that we don't really choose the functional datum features, we have to discover them.  The geometry and the assembly method determines how the part's degrees of freedom will be constrained.  Our task is to find a way to describe the constraint using the tools in Y14.5.  We sometimes find that the Y14.5 tools are not able to completely describe the functional situation, or require overly obscure and confusing callouts in order to do so.  It is often more workable to sacrifice some functional "correctness" and go with a more palatable approximation.
This is what we'll probably find with the cover bosses.  Those obrounds are nasty, because they're irregular shapes that masquerade as simple features of size.  We try to create simple datum features on them and it doesn't work, because they don't function as features of size.
That said, let's try to discover the functional datum features and find some way to reference them.
The arrangement in the ANGLED-DATUM.tif diagram is getting closer, but I still don't think it's quite right.  Imagine the cover being pushed and turned on the channel, and picture where the contact will be.  I would argue that the "outer" round ends of the bosses constrain the DOF's just as much or more than the flats, particularly translation in the left/right direction.  So those outer round ends need to be included in the datum feature(s).  The inner round ends of the bosses won't contact the channel, so those should not be included.
We need a datum scheme that would result in the datum feature simulators shown in the attached diagram.  The two simulators are fixed in location relative to each other.  Their inner surfaces represent the worst-case outer boundary of the combined boss pattern.  This boundary would be derived from a Surface Profile tolerance on the boss pattern.  I believe that the way my actual part sits on this simulator set is in line with how an actual cover would sit on a worst-case (i.e. smallest) channel.  Neither boss is aligned exactly with its simulator, and there is some clearance.
Now how can we get this using Y14.5 datum referencing techniques?  Any ideas?
Evan Janeshewski
www.axymetrix.ca
Quote (SDETERS 12 Nov 09 15:23):
If this is true, and at some point we have to take the OP's word for it winky smile then I think using the widths adequately constrains it.  If the obround bosses are 'over long' then the rounded ends might come into play but the wouldnt' there be a fit concern?  I suppose if they are relatively narrow compared to the slot then your specific concern becomes more significant.
I think tolerancing it so that the ends of the bosses don't touch the ends of the channel and are not too sloppey on width then simplifies the problem to one that my sketch of Mech North's idea adequately addresses.
axym,
That is it, "The way I like to think of it is that we don't really choose the functional datum features, we have to discover them."
That is one of the things I am trying to say in my philosophy thread, the parts/assembly works the way it works, we need enabling tools to help us describe it and not arbitrary prohibitions that stop us from doing the job. We as designers can determine some of it if we in fact have a clean sheet. Other factors come in and in the end we just want to document the actual condition.
KENAT,
I went the other way with the round ends and the widths.  I guess I didn't take the "located by the side walls" thing that literally.  I thought that the two outer rounded ends would constrain the DOF's very well on their own, and the widths just get in the way.  The bosses are only obrounded because the engineer "likes the look of them" and sdeters would have preferred to make the bosses cylindrical.  This would be a much more efficient datum feature design - the extended length of the bosses just provides more material to control.  The datum referencing would be much simpler as well - something along the lines of sdeters's original drawing would work fine.
Evan Janeshewski
www.axymetrix.ca
Tks Kenat; excellent graphic of exactly what I was thinking.
Evan, how very Zen of you!  I have to remember that one; mind if I use it in classes?  From a mechanical design perspective, unless the widths of the bosses and slots are modified at LMC, you would never get the radial ends to make contact with the ends fo the slots without fighting against the angle and therefore distorting the rubber part.  The configuration as provided would find its own natural origin during assembly, and it would be independent of the ends of the slots/bosses; in Kenat's graphic, the origin of meaurement is at the intersection of the two datum planes.  If the gasket was to be press-fit between the ends as suggested in Evan's graphic, and buckling or compression of the material was ok, then I'd use datum target areas.  Could use targets K1 & K2, referencing only A/K in the DRF, or use K1,M1, and reference A/K-M in the DRF; same effect.
Jim,
I'm not sure what part of my graphic suggested a press fit, but that definitely wasn't the intent.  Are you referring to Boss_datums_3.pdf, with the two U-shaped simulators?  If you look closely, the bosses aren't actually touching the simulators (perhaps I should have exaggerated the gaps a bit more).  The idea was that the simulator geometry is derived from the bosses' outer boundaries, so that the bosses would always have at least zero clearance with the simulators.
KENAT,
In your ANGLED-DATUM.tif diagram, what was the intention for how datum features Y and Z would be referenced in a feature control frame?  Specifically, in what sequence and at what material condition?  Perhaps Jim can shed some light on this as well.  I'm still having trouble seeing the advantage of using the two widths as datum features.  It doesn't seem like they would control the left/right translation as efficiently as the round ends would.
Evan Janeshewski
www.axymetrix.ca
Evan, first, keep your life jackets nearby ... how are you enjoying the weather in Vancouver this week?  Next, didn't notice the gap, sorry.  Interesting question on how to reference them; a hyphenated datum reference (/X/Y-Z/) would likely be better than two individual references (/X/Y/Z/), though it would still be legal.  The only way that I can see value in using the radial ends & therefore the net boundary would be if the the boundary is specified at MMC so that there is mega-slop so that the radial ends may actually have a chance of coming into play.  Typically with something like this, I'd design it with clearance at the ends of the slot and maybe even a light-press fit on the widths of the bosses; the inclined boss would do a great job of constraining left/right motion and fully constrain the vertical motion in conjunction with the horizontal boss. Because of the flexible nature of the material, I don't think that Y will do an adequate job on vertical constraint by itself.
Hey all,
Sorry I have been out of the Eng-tips forum for so long. I even kept a bunch of notices trying to get back.  Anyway, I be trying to be more active.
As for this thread, already long enough, I have to go with Jim on this through all the speed reading.
I know perhaps you want more out of me, but I have a lot of catching up to do and fundamentally what I read is that Jim, not surprising, has a handle on this one.
Norm
Norm Crawford
GDTP-S
Applied Geometrics, Inc.
www.GDandT.com
Jim - most likely in Dayton since I live very close! But never know, I could be in China too.
Norm Crawford
GDTP-S
www.GDandT.com
Going on the comment of "The cover is located by the side walls of the casting. " is why I'd go with the width as the datum, using logic like MechNorth.  As to how to reference them, it depends what you have to relate to them, if it's just the non critical outside profile then it doesn't make much difference does it?
Interesting comments KENAT.
It still surprises me how different my instincts often are from those of you in the design field.  How you reference the datums makes a lot of difference, especially to the inspector! And to the material review board tasked with dispositioning nonconforming parts, when this "non critical" outside profile somehow failed inspection even though the parts work fine.  And to the quality manager, when the assemblies have less than the required .050" of overlap even though the detail parts passed inspection.
The functional datum features are what they are.  You can specify something else if you choose, but that doesn't change how the DOF's will get constrained in the assembly.  All it changes is how the inspector will be obligated to constrain the DOF's during inspection.
Even after all of this discussion, we never did give DSETERS a good answer for how to specify a good datum scheme for the functional situation as described.  Jim, you said that the only way the rounded ends would come into play is if everything is at MMC and there's mega-slop.  Well, that's what the situation actually is!  These bosses interface with an as-cast channel with .050 profile tolerances on the surfaces.  There is going to be slop!  But you suggested changing the design to take the rounded ends out of play and perhaps put a press fit on the widths.  Are we redesigning the part now?  If we are, why not just make the bosses round?  I'm not a design engineer, but I can't see how the widths can constrain the left/right translation more efficiently than the round ends would given the part geometry.  If there was a .005" gap between the boss widths and the channel, the cover could move left or right by about .015".  Let me know if I'm completely out to lunch here.
I guess I'm more used to working within the confines of a given situation as opposed to changing it.  This mindset probably comes from years in the CMM room, trying to reverse-engineer the real functional datum features of a part in order to make sense of nonsensical inspection results.
Sorry about the bitterness and ranting.  I just remember that whenever there was a disagreement over part conformance or inspection results, the three most common causes were:
1. Datum Reference Frames
2. Datum Reference Frames
3. Datum Reference Frames
Evan Janeshewski
www.axymetrix.ca
Not advocating a redesign for the OP, Evan, just proposing "what ifs" as they would simplify(?) the situation.  I'm not comfortable using a partial contact of the radial end of the boss to constrain motion as a first-contact will in reality be at a couple of points, and full contact won't be made until the rubber is compressed.  The long surfaces of the boss will (probably) make greater contact with the channel and therefore are less likely to deform significantly vs the end radii in actually constraining motion.
You are right that design & inspection often have different (& often conflicting) understandings and instincts.  It all comes down to the design intent, and unfortunately I often see that designers pay only casual attention to the actual functionality vs the pereived functionality.  I was a victim of this until I was lead through an extended "5-Why" session to get to the root functionality of components in a system.  Quite an exercise and experience, but not a popular design philosophy.
Well, while you most likely have a point as you most likely know more about it than I...
If the outside profile is truly relatively non critical then I'd hope it would have a tolerance that reflects this and that is well within process capability and so chances of one being far enough off to be rejected is correspondingly small.  Or something like that.
If there is some other interface or functional concern that the OP hasn't shared with us (or I missed) then I'd look more closely.
I sometimes wonder if, especially on non critical parts, we spend too much time trying to find the 100% correct, all things considered solution, when a 99+% solution could be found for a lot less time and effort.
I think most people I work with don't go far enough, but I sometimes wonder if on here we don't get a bit carried away occasionally.
Really like your last 2 pts, Kenat.  I look at this forum as an opportunity to go to the N'th degree in a theoretical discussion.  Exposure over time to (decent) design, manufacturing and inspection can help guide us toward the practical and away from the impossible perfect.
Participation is voluntary; I like exploring ideas with people who seem to be well versed on the subject.
I spent a half hour today arguing with a guy (the chief representative of quality and head of our new GD&T "A" list, we are currently preparing to adopt the 1994 standard) who insisted the standard requires datums to be in alphabetical order ABC, DEF, primary, secondary, and tertiary "the don't have to start with "A" but they have to be in order, that is the way they show it in the book and it's supported by 4.4".  I was shocked, I couldn't believe my ears. I finally found the statement in 3.4.3 "datum reference letters need not be in alphabetical order".  I said: "if what you say is true, they would always be in order". After reading and thinking he said: "oh, I don't have time to argue about this anymore".
My point is some of us need to have a place were we can discuss issues.
To add to the last point of Fsincox, an increasing number of companies have only one or two GD&T SMEs these days, and almost none have GDTPs, so it's especially important that a forum like this exists for them.
There are other forums too.
This is a good one.
But man it can eat up some time. lol
I would list others but I don't wnat to break any rules or step on toes.
Norm Crawford
GDTP-S
www.GDandT.com
No doubt that these forums eat up a lot of time.  The reasons that I justify spending the time are that I learn a lot from the other members, that I think I can be help them learn as well, that I find out what issues people are facing, and that trying to explain myself sharpens my own understanding as well as my ability to communicate it.  I've had a lot of "aha" moments thinking through issues that were brought up on this forum.
It might also be that I'm one of those freaks who actually enjoys debating Y14.5 minutiae for it's own sake.  Sad but true.
Evan Janeshewski
www.axymetrix.ca
You attend the Y14.5 meetings, Evan...yes, you are one of those freaks.  Add to that the fact that you're from Vancouver, and whoa Nelly!  pipe  Norm and I (and a few others here that attend the meetings) aren't freaks of course, because we're from the extended rust belt where people are well grounded.tongue
When the OP is a fairly direct question, not an invitation to discuss or debate a topic, and especially if they appear relatively inexperienced in GD&T I try to give a fairly direct answer and not get too caught up in intricacies.  To do this I will sometimes make some assumptions (yes at the risk of making an ass...), although I try and qualify these to some extent.
When it is more of a discuss/debate question or just very complex then I tend to just let you smart folks with GD&T letters after your name have at it and just follow along till my brain starts to smoke (usually about ½ way through the OP).
I can't claim to stick rigidly to either of these principles but try to generally follow them.
That's not to say others approaches are wrong, however I know I have got frustrated when my threads have been taken off on a tangent or gone into much greater detail etc. than I desired/needed, so I try to "do as you would be done by".
Now I've gone and taken this off track though, doh!
