contact problem
contact problem
I want to model a steel silo under earthquake excitation.
I used a umat subroutine for constitutive behavior of granular material (hypoplastic mateial with inergranular strain) I tried to model a steel silo with granular material under earthquake excitation with Abaqus standard. I modeled silo walls and bottom with 4 node shell elements and granular material with 8 node solid elements then I used surface to surface contact between silo walls, silo bottom and granular material, when I use default hard contact for normal behavior of contact in Abaqus standard I have overconstraint problem due to using contact pair and earthquake motion applied to the silo bottom as acceleration boundary condition together, and when I use penalty or augmented lagrange method for normal behavior of contact, I encounter two type of warnings
in first step that I apply gravity load the waring is
1)During back substitution 625 elements encounter a load applied to a degree of freedom that does not have any stiffness. The elements have been identified in element set WarnElemBackSubNoStiffStep1Inc1.
and in second srep the warning is
2)There are 2 unconnected regions in the model.
when I increase stiffness scale factor the first waring is ommied but in the second step I have warning that says
in fact solid elements penetrate into silo wall and my model becomes unstable. please help me I am completely confused.
RE: contact problem
Rob Stupplebeen
RE: contact problem
RE: contact problem
If one body passes through another then you haven't made contact for whatever reason. As in all these cases, start with a dummy load case of fixed displacements to ensure some contact is made before applying your real loads.
corus
