Full nozzle or semi nozzle - pressure safety/relief valve
I think I know the mechanical difference between the two: 'In a full nozzle valve, only the nozzle and disc are exposed to the fluid media when the valve is closed. In a semi nozzle valve, the nozzle, disc, and part of the valve body are exposed to the inlet fluid when the valve is closed'
But when come to choose the valves, which one should I use? Is it purely based on pressure? I remember read somewhere 'if the pressure is high, full nozzle should be used', is it true? How high is high? I'm working on a project with design pressure of 15Barg, so I decided to use semi nozzle, is it ok?
Cutie
Cutie
RE: Full nozzle or semi nozzle - pressure safety/relief valve
JAC
Cutie
JAC
