Cooling Medium Foaming
Our platform is experiencing issues with foaming in its closed loop Cooling Medium System.
Has anyone ever had any issues of this type?
If so, what was the route cause, the short term and long term fix?
Your comments will be greatly received.
RE: Cooling Medium Foaming
However, the reason for this may have been linked to leakage across the valves used to feed either steam or refrigerant to reaction vessels causing cross-contamination (and the reason to keep a close eye on concentration - too much water and the refrigerant would freeze!).
JMW
www.ViscoAnalyser.com
Good luck,
Latexman
